Cannot Find Kollmorgan AKD in Workbench
Updated Oct 18, 2018
I have my hardware connected and can see my cRIO in NI MAX, but why can't I see my AKD in workbench? How do I fix this?
If you cannot find your Kollmorgan AKD in Workbench, first confirm that you have all the hardware correctly connected: the Service Port (X11) on the AKD is directly connected to your Machine via an Ethernet cable; re-open Workbench after this is confirmed.
If you are still unable to find your AKD in Workbench, there may some other issues that are laid out by a Kollmorgan Article: Why can't I see my AKD drive when I try to connect in Workbench?
