Modular Data Acquisition
High-Performance Test
For DAQmx:
Implementation of NI-DAQmx is the same as other text based programming environments . For programming the Real-time Controller:
Note: To create a complete application where the real time controller has access to the hardware I/O you will require to program the embedded FPGA. In order to program the FPGA you can only use the LabVIEW FPGA module.If you are new to programming in an embedded system, first learn about general methods and other tools that are available.
