Calling a Sequence Multiple Times in TestStand
Updated Aug 22, 2018
  • TestStand
I have multiple sequences that run in parallel. What happens if I call the same sequence twice from separate places. Does this cause a resource conflict?
As long as you call a sequence as a new thread, this sequence can be called multiple times even if it is still running with out causing a resource conflict. This is because it runs as a new instance each time it is called. This is assuming that the code within the sequence can be called multiple times. For example does, not utilize Daq hardware which is limited to 1 connection at a time.
