Calling Python Class Methods Using Python Node in LabVIEW 2018
Updated Jan 27, 2026
  • LabVIEW 2018
Programming Language
  • Python
Other
Python 2.7
How can I call python class methods defined in my python script using the LabVIEW python node?
Unfortunately, there is no direct way to call python class methods using the LabVIEW 2018 python node. However, you can implement a wrapper function in your python script which then can be called using the python node. An example of such a wrapper functionality could look like this:
  • Python script
#define class
class myClass(object):
    def __init__(self, parameter):
        self.__Parameter = parameter
    def GetValue(self):
        return self.__Parameter
#define wrapper for LabVIEW Python node
def getClassData():
    newClassObject = myClass(4882)
    return newClassObject.GetValue()
  • LabVIEW 2018 block diagram to call the wrapper function
According to Support of Python Object in LabVIEW Python Node, NI officially support Python object in LabVIEW version 2022 Q3 and above. Refer to the related link to learn how you can implement Python object into your latest LabVIEW version!
