PXIe-4464 Not Showing in MAX
Updated Aug 21, 2018
  • PXIe-4464
I have the NI-DAQmx driver, but my PXIe-4464 is not showing up in MAX.
PXIe-4464 is a newer card, and older versions of NI-DAQmx may not support it. Check the readme files of the NI-DAQmx driver you are using to see if PXIe-4464 is listed as a supported product. If not, upgrade your driver. Drivers are generally compatible with LabVIEW versions three years back. For example, LabVIEW 2013 will support up to NI-DAQmx 17.0.
Downloads: NI-DAQmx
