How to Stop the Scrollbar for Adding New Columns and Rows?
Updated Oct 10, 2018
I would like to have a table with fixed number of Cells and Rows. I use the property node 'Number of Columns' and 'Number of Rows' but when user clicking on the scroll bar the number increased that is not desired and would like to fix it.
One work around is to fit the table into the panel and disable the scrollbars if your table is not that big.
The number of rows and columns might change if the horizontal and vertical scroll bar is visible. This property counts partially visible rows and columns.
