Wrong Data or Information when Running CompactRIO Headlessly
Updated Jul 9, 2019
  • CompactRIO Controller
  • LabVIEW Real-Time Module
I am logging data to a TDMS file with a CompactRIO. When running interactively (from LabVIEW) I get the right header information, but when I run it headlessly I don't get any information (it shows up as Untitled in the TDMS file). Why?
Make sure you aren't trying to obtain Front Panel properties on your CompactRIO as shown below:
Because CompactRIOs don't have access to Front Panels when run headlessly, Property Nodes referencing Front Panel objects will not return any values. You can instead do any of the following:
