NI-FGEN Express VI Does Not Show My NI FGEN Device
Updated Sep 17, 2018
  • PXIe-5413
  • PXIe-5423
  • PXIe-5433
  • NI-FGEN
I have a PXIe-5413/5423/5433 waveform generator and am trying to use the NI-FGEN Express VIs. However, when I try to use the express VIs it doesn't list my device under devices.
This is a known issue with these particular waveform generators. The CAR ID for this is 623127. The work around is to start with the NI-FGEN examples and create a SubVI to suit your application needs.
To get the the NI-FGEN examples follow these steps:
  1. Open LabVIEW.
  2. Select Help >> Find Examples...
  3. Under the browse tab, select folders Hardware Input and Output >> Modular Instruments >> NI-FGEN (Signal Generators)
  4. Here you will find subfolders that have LabVIEW examples to do different actions depending on your application.
