Where Are the Measurement Studio 2015 Merge Modules?
Updated Sep 13, 2018
  • Measurement Studio
I am trying to deploy my Measurement Studio 2015 application, but cannot find the 2013 version merge modules. Where are these located at?
I am using Measurement Studio 2015, does it come with merge modules?
There is a known issue with the Measurement Studio 2015 .NET Merge Module help page. If you would like to use merge modules for your installer, you will use the 2012 version merge modules. Instead of the Measurement Studio 2015 .NET Merge Module help page, follow the Measurement Studio .NET Merge Modules White Paper. The White Paper contains detailed information on the merge module versions and locations.
Instead of merge module deployment, National Instruments recommends utilizing the appropriate Runtime Installer and Installer Builder.
If you have DAQmx installed and are running into linking errors referencing Common Merge Module 2013 when including the 2013 DAQmx Merge Module, you can upgrade to DAQmx 16.1 or newer. There is a known issue with the merge module that has been resolved in DAQmx 16.1 and newer.
