Can Digitizer Use Whole Onboard Memory for 1 Channel?
Updated Sep 3, 2018
  • PXI Digitizer
  • NI-SCOPE
I have a digitizer device and know its onboard memory size. But I'm not sure this memory is sharing by whole channels, or can be used by only 1 channel. For example, my PXIe-5144 has 16 MB onboard memory. Can I use 8MB, or 16MB for 1 channel?
The onboard memory is sharing between channels. If you enable only 1 channel, you can use whole onboard memory for the channel.
