Generate Fix Amount of Pulses Using VirtualBench
Updated Aug 21, 2018
  • VirtualBench All-in-One Instrument
Can you use the NI VirtualBench to generate fixed train pulses?
One way to generate fixed pulses with the VirtualBench is by automating it using LabVIEW. This method uses the concept of time elapsed to start and stop the VirtualBench. The example below demonstrates this by generating 2 100Hz pulses.
