How Long Does the Power Button on My PXIe Chassis Needs to Be Held to Cause a Power Cycle?
Updated Aug 20, 2018
  • PXI Chassis
The inhibit mode switch on my PXIe chassis is in the manual position. Is there a set number of seconds the power button on the chassis needs to be held to cause a power cycle?
The amount of time you'd have to hold the power button is dependent on several things including what cards are in your chassis, what software you're using, etc..
Holding the power button for 10-15 seconds is more than enough time to ensure that the system generates a full power cycle.
