Error 2350 Running LabVIEW-Built Installer
Updated Oct 30, 2018
  • LabVIEW Professional
I built an installer for my LabVIEW application, and when I try to run it on another computer, it returns the message The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2350.
It also points to not being able to install components like NI Measurement Studio ComponentWorks 3D Graph or corrupt cabinet files like (543364i.cab or swCA4_64.cab.
How do I resolve this error and install my application?
This can be caused by antivirus or other security protocols on the computer blocking the installation. Try the following:
  • Right-click the setup.exe and select Run as Administrator
  • Disable antivirus software.
If this is still failing, check with your IT team to ensure that you are not blocked from installing components to the end system.
This issue can also happen as a result of corrupted software in the development computer. If the previous suggestions don't help and you are not sure what software the error messages are referring to, contact NI Support to get help identifying what software components may need to be reinstalled.
