How Can I Record Which Button Was Pressed in a Message Popup Step in TestStand?
Updated Sep 17, 2025
  • TestStand
I want to know which button a user pressed in a message popup step and save this to a local variable
To do this, go in to the Message Popup step Properties tab:
Go to the Post-Expression box in the Expressions settings:
Enter the following expression:
Locals.<variable name> = Step.Result.ButtonHit
This will retrieve the name of the button that was pressed (Step.Result.ButtonHit) and save it in the specified local variable as a string.
Once implemented, select a button on your message pop up step - In this example the second button "2" has been selected.
A break point is set to view the updated variables:
