NI IMAQ Vision C API Documentation
Updated Aug 17, 2018
  • LabWindows/CVI
  • Vision Development Module
  • NI-IMAQ
  • NI-IMAQdx
Programming Language
  • C
  • C++
I am using the NI Vision Development Module to develop my NI Vision application in C. Where can I find documentation on the image processing and NI IMAQ functions?
If you're working in the LabWindows/CVI environment, you can open the Function Panel for the function you would like more information about. In the Function Panel, you can right click the empty space to get a description of the function. When you right click on a parameter in the Function Panel, it will give you a description of the parameter.
If you are not in the LabWindows/CVI environment, you can access the NI Vision C Support Help in the following location:
<National Instruments>\Vision\Help\NIVisionCSupport.chm
The NI Vision C Support help documentation has an alphabetical list of the functions that you can use to browse for a specific function if you are unsure what category your function should be listed under in the NI Vision Library Function Tree.
