Memory Is Full When Using Channel Wires
Updated Aug 30, 2018
When I run my application that contains channel wires, a memory is full error shows up. What can I do monitor it or stop memory getting full?
These are some best practices to stop your memory getting full when using channel wires.
1. Utilizing the Profile Performance and Memory Tool to monitor the Max Bytes usage of channel wires.
2. Make sure that for every open reference there is a close reference. This stops the buffer getting full and increasing the memory.
3. Remove any writers connected to the channel wires that do not have any readers.
