Modular Data Acquisition
High-Performance Test
Using enums in TestStand without LabVIEW was a feature added in TestStand 2016. If you are using a previous versions of TestStand, you must create an enum in LabVIEW and call it in TestStand.Further details can be found in Enumerations in TestStand Expressions - TestStand Help, to create programmatically a enum variable using the TestStand API refer to How Can I Create Programmatically an Enumeration Variable in TestStand?
