While Loop Is Expanding When I Add Functions Inside it
Updated Sep 17, 2018
When I am on the block diagram in LabVIEW and try to add any object to my loop, I get an unexpected behaviour and the loop just increases in size.
The reason this is happening is because of a Windows display setting related to the Dots Per Inch (DPI) feature. To change this go to your Display Settings in Windows and change the Scale and Layout to a value less than 125%.
