Playing .WAV Sound File from LabVIEW
Updated May 22, 2026
I want to play a .WAV sound file in LabVIEW. How can I do this?
The sound palette is located in the Functions Palette under Programming>>Graphics and Sound>>Sound. Select Output and you can use the following two VIs to play a .WAV file:
  • Play Waveform VI
  • Play Sound File VI
The Device ID terminal is the device you access for a sound operation, which is generally 0 by default. The Play Waveform VI includes an auto-populated drop-down list of all available sound devices. For more details, refer to Context Help in LabVIEW.
To find the example code, select Help » Find Examples in LabVIEW. In the NI Example Finder, select the Browse tab and navigate to Hardware Input and Output » Sound. To play a .WAV file, start with the Sound File to Sound Output VI example.
If your
.WAV is not in the standard .WAV file format you may get the error 4810:
Ensure the file uses a standard .WAV format to avoid this issue.
