I'm Missing The TestStand Run Time Executable
Updated Aug 31, 2018
  • TestStand
I've downloaded and installed the TestStand Run Time Engine, but when I try to run my sequence files I can't seem to find the executable (.exe).
Is my installation corrupt or am I missing some steps?
The TestStand Run Time Engine does not include an executable to run sequence files.
Similar to the LabVIEW Run Time Engine, you need to use the Deployment Utility to create a full test system deployment to be able to run it on a PC without the sequence editor installed.
