Invalid Serial Number When Installing ELVISmx
Updated Aug 24, 2018
  • SignalExpress
  • Multisim
  • NI-ELVISmx
When installing NI ELVISmx I receive a message stating that my serial number is invalid. How can I fix this? I am sure that I use the correct number because I read it off the packaging.
This message will occur unless you install an application development environment (ADE), such as NI LabVIEW, Multisim, or Microsoft Visual Studio®, before installing NI ELVISmx.
For example, NI ELVISmx 16.0 supports the following NI ADE versions:
NI Application SoftwareVersions Supported by ELVISmx 16.0
NI LabVIEW (32-bit versions)NI LabVIEW 2013, 2014, 2015, and 2016
LabVIEW SignalExpressSignalExpress 2013, 2014, and 2015
MultisimMultisim 12.0, 13.0 and 14.0
NI ELVISmx 16.0 is an application software that supports the National Instruments Educational Laboratory Virtual Instrumentation Suite II/II+ (NI ELVIS II/II+) and the NI myDAQ.
