Probe Display Does Not Match Value in Probe Watch Window
Updated Aug 15, 2018
I am probing a string wire, and see that the value in the Probe Watch Window is empty. However, the probe display shows the correct value that I am expecting.
This can happen if there is a null character at the start of your string. You may use the String Subset function, with an offset of 1 to remove the null character at the start.
