You can use the property of the Vision Assistant called the ROI Descriptor. To access this property in Vision Assistant, you will make a step that uses the ROI. Then click Set Controls.
![](/servlet/rtaImage?eid=ka03q000000ZHs3&feoid=00N3q00000HUsuI&refid=0EM0Z000000Re5a)
When you are in the controls section, make sure ROI Descriptor is selected.
![](/servlet/rtaImage?eid=ka03q000000ZHs3&feoid=00N3q00000HUsuI&refid=0EM0Z000000ReBs)
After that you will be able to change the values of the ROI. You can also create a ROI property node from your Image Indicator to read a drawn ROI from the front panel. You should do this for the image you acquire before processing with the Vision Assistant. You will need to create a second Image Indicator after the Vision Assistant to see the results of your ROI changes.
![](/servlet/rtaImage?eid=ka03q000000ZHs3&feoid=00N3q00000HUsuI&refid=0EM0Z000000ReCv)
