MAX Freezes When I Try To Make a DAQmx Task
Updated Feb 27, 2019
When I try to create a task in NI MAX i see the program freeze after I select the hardware in the task creation wizard. I have to use the task manager to quit out of the program.
This can be caused by a corruption of the DAQmx driver upgrading to the newest version of the DAQmx driver can often resolve this. If the problem persists after you restart, please contact NI support.
