Error -2147138275 in VeriStand : Using the Scan Engine and EtherCAT Custom Device
Updated Aug 21, 2018
  • VeriStand
I am changing bitfile's working variables but I get the following error:
Error -2147138275: A mismatch was found between user-defined variables deployed and running on the slave FPGA.
How can I fix it?
When you change the working variables and encounter this error you should follow these next steps:
  1. Download the new bitfile with the system explorer
  2. Reboot the master
  3. Reboot the slave
  4. Deploy
