이 내용은 고객님의 설정 언어로 확인할 수 없습니다
Generate Software Timed Trigger with NI-DAQmx in LabVIEW
Updated Sep 19, 2025
  • CompactDAQ Chassis
  • CompactRIO Chassis
  • PXI Chassis
  • PXI Digital I/O Module
  • Digital I/O Device
  • Analog Output Device
  • C Series Universal Analog Input Device
  • I have an NI hardware configuration and I want to use one digital or analog input signal to trigger a particular task or operation on my LabVIEW code.
  • I want to synchronize two tasks to execute one after the other, and my NI hardware configuration does not have the physical channels to perform a hardware trigger.
A software-timed trigger can be implemented by continuously monitoring the status of an input signal within a while loop. When a specific condition is met—such as a threshold being crossed—the loop exits and the DAQmx Start.vi is called to initiate the desired task.
The following code snippet demonstrates how to create a software-timed trigger using an analog input. In this example, an analog voltage value from the DAQ Assistant is monitored, and once it exceeds a defined threshold, it triggers a separate DAQmx Analog Input Task.
Note: The DAQ Assistant VI can be substituted with a digital input task if your application requires digital triggering instead.
Block Diagram:
Note: This image is a LabVIEW snippet, which includes LabVIEW code that you can reuse in your project. To use a
snippet, right-click the image, save it to your computer, and drag the file onto your LabVIEW diagram.
False Case:
The software timed configuration will run at one rate determined by the computer's Operating System and how it prioritizes the tasks currently ongoing. In this way, we should expect a high latency on the application.
