このコンテンツは設定された言語で表示できません。
Generate Software Timed Trigger with NI-DAQmx in LabVIEW
Updated Oct 22, 2023
  • CompactDAQ Chassis
  • CompactRIO Chassis
  • PXI Chassis
  • PXI Digital I/O Module
  • Digital I/O Device
  • Analog Output Device
  • C Series Universal Analog Input Device
  • I have a NI hardware configuration and I want to use one input signal to trigger a particular task or operation on my LabVIEW code.
  • I want to synchronize two tasks to execute one after the other and my NI hardware configuration does not have the physical channels to perform a hardware trigger.
A software timed trigger can be done monitoring within a while loop the status of the input signal of one device to check if a certain condition has taken place. If this condition occurred then the LabVIEW program will execute the desired task using a case structure.
For example, if we want to create a software timed trigger, where a DAQmx Voltage Digital Input Task will trigger a DAQmx Analog Input Task, the following implementation can be done:
Block Diagram:
False Case:
The software timed configuration will run at one rate determined by the computer's Operating System and how it prioritizes the tasks currently ongoing. In this way, we should expect a high latency on the application.
