My FPGA Compilation Fails With the Error - cincorrectmodule is not declared
Updated Apr 4, 2018
  • NI-9852
  • NI-9853
When I compile my FPGA code, it fails with errors. Checking the log file, I find that the 'cincorrectmodule is not declared'.
To fix this issue, you will need to enable error terminals on all NI 985x IO nodes in your code.
This is a known bug. Please read below for more information.
This is a known issue for the December 2017 CompactRIO driver. On the linked page, you will see it under issue #679827.
This issue applies to NI 985x FPGA IO Nodes in all cRIO targets except for the cRIO-904x line.
We are currently working on a fix, and you can check the ReadMe on future CompactRIO drivers for #679827 to see if it has been fixed.
