Custom Board RMC Connections with sbRIO-9637
Updated Apr 6, 2018
  • sbRIO-9637
  • Daughterboard for sbRIO Controllers
  • sbRIO-9627
I'm trying to build a custom daughter card and connect via RMC connector to my sbRIO-9637, is this the best sbRIO intended for this use?
While this is something that can be implemented, the sbRIO-9637 doesn't come with a RMC connector preinstalled. The sbRIO-9627 has an RMC connector built into the board and is better intended for use with custom daughter cards.
The sbRIO-9627 has the same form factor as the sbRIO-9637 and more digital lines available.
