When checking for compatible hardware, you should verify what version of DAQExpress you have installed. You can do this by opening DAQExpress and selecting
Help >> About DAQExpress on the toolbar.
You should then verify that DAQExpress is
compatible with your installed version of
NI-DAQmx. Ethernet cDAQ chassis (e.g. cDAQ-9185) are not yet supported with DAQExpress, while USB cDAQ chassis (e.g. cDAQ-9178) are.
