LabVIEW RT FIFO Only Outputs One Element In The Array
Updated Apr 10, 2025
  • LabVIEW Real-Time Module
In LabVIEW, I am writing an array of data into an RT FIFO. When I read from that RT FIFO, I only read an array with one element in it.
When creating the RT FIFO and defining the FIFO size, you must not only specify the number of elements in the FIFO (the number of arrays that can be in the FIFO, indicated by the size input) but also define how many elements are going to be in the arrays themselves.
Do this by adjusting the elements in array input. This is by default 1, so change this to a suitable size for your application.
Regular FIFOs can allocate memory dynamically which make them easier to work with, but non-deterministic in nature. However, to keep RT applications determininstic, memory is preallocated when working with RT FIFOs.
