How to Ignore Trigger Timeout Error of Basler Camera
Updated May 25, 2018
  • Camera
  • NI-IMAQdx
I need to acquire image from a Basler GigE camera with a trigger signal from our system.
Currently I have a problem with the timeout error, can I ignore timeout error?
  1. Open the following example and make your application on its base: Help >> Find Examples ... >> Hardware Input and Output >> Vision Acquisition >> NI-IMAQdx >> High-Level >> Grab.vi
  2. Select your camera in Camera Name (cam0)
  3. You also need to add the configuration of your camera. The recommended configuration method is shown in the example Help >> Find Examples ... >> Hardware Input and Output >> Vision Acquisition >> NI-IMAQdx >> High-Level >> Grab and Basic Attributes.vi.
  4. Add ignoring the error on the trigger using Clear Errors.vi with the corresponding error number.
