Failed to Connect to the Target When Using a NI Real-Time Target in LabVIEW
Updated Aug 27, 2026
  • CompactRIO Controller
  • roboRIO
  • PXI Controller
  • myRIO Student Embedded Device
  • NI ELVIS III
  • LabVIEW Real-Time Module
  • NI-RIO
  • I have a LabVIEW project containing a Real-Time (RT) target that I used to be able to connect to. I moved the project to a new computer, and can no longer connect to the RT in LabVIEW, even though it is on the same network.
  • When I try to deploy Real-Time code to my CompactRIO, LabVIEW attempts to connect to the target before failing. What is causing this?
  • My NI Real-Time Target is detected correctly in NI MAX. However,
    • When I try to use it from LabVIEW, I can add it to my project but I can't connect or deploy to it
    • When I try to use it from LabVIEW by clicking Connect in the target, I see a message that displays one of the following errors:
This issue can be caused by several reasons, please check the points below:
  • Make sure the device shows up in NI Measurement and Automation Explorer (NI MAX). If it does not show or comes up as disconnected, follow the guide to troubleshoot getting the device to show up in NI MAX: NI CompactRIO or Network Device Doesn't Show Up or is Missing in MAX.
  • Make sure LabVIEW Real-Time Module is installed on the host PC.
  • Make sure that the IP address in the LabVIEW project is the same as the IP address shown in NI MAX. If the IP addresses do not match, right-click the RT target and select Properties. Then, in the General category, modify the IP address to match the IP address shown on NI MAX.
  • Once you find your device in NI MAX, click on it and then look at the System Settings tab on the right.
    1. Make sure that under the Startup Settings section, Force Safe Mode is not checked and LabVIEW Project Access is checked.
    2. Make sure that Status is showing Connected - Running
      • If it shows Disconnected, go back to step 1.
      • If it shows Safe Mode, check again to make sure that Force Safe Mode is not selected and that if your cRIO controller has DIP switches that the Safe Mode switch is not in the on position. Power cycle your device and check again. Refer to the hardware's manual for more information regarding its Safe Mode.
    3. Run Remote Systems >> Troubleshoot Remote System Discovery wizard. This should check software compatibility and firewall settings. If your firewall settings are shown as blocking NI software, use Add Rules to correct this. If this doesn't work, you can manually add the rules.
  • Check that you have the correct software installed on your computer and CompactRIO target: Preventing Software Compatibility Issues for CompactRIO Systems. Make sure that your version of the CompactRIO Driver installed is compatible with the version of LabVIEW you are using.  You can check for this information in CompactRIO Device Drivers and LabVIEW Compatibility or your CompactRIO Device Driver Readme file.
  • It's possible that LabVIEW can't connect to your target because there is a problem with the software installed on the target or with the LabVIEW Real-Time service (nilvrt) running on the controller. To fix the issue, format your controller using NI MAX and reinstall the software. Make sure the version of LabVIEW you are using matches the version installed on your Real-Time controller. For example: If you are using LabVIEW 2022 (with its 2022 Real-Time Module), you would install LabVIEW Real-Time 2022 from NI MAX.
  • Real-Time targets can be in safe mode for a number of reasons, including:
    • user forced software safe mode (via NI MAX)
    • user forced hardware safe mode (via DIP switches)
    • there is no software installed on the CompactRIO controller
    • the CompactRIO has crashed a number of times and has then booted into safe mode
  • It is always recommended to install software to the Real-Time Targets via a direct cable connection. This can be USB or Ethernet. This protects the integrity of the installation.
  • Try using a different USB port on PC or reseat the cable on both ends in order to ensure connection is good.
  • If having the issue when using 2023 Q3 base image system, consider upgrading to the 2023 Q4 base image system.
  • Upgrade the CompactRIO firmware version to the latest available version available in your host PC. Using old version of firmware with newer version or Linux RT System Image (e.g., firmware version 7.0.0f0 with Linux RT System Image 2022Q4) can cause this issue.
