What Are TDMS Files and How Can I Use Them in My LabVIEW Program?
Updated Sep 21, 2022
I have seen technical data management streaming (TDMS) files described as a high performance file type for storing and accessing binary data within LabVIEW. What are these files and how can I use them in my LabVIEW program?
The TDMS file type is designed by NI to store measurement data. This proprietary file type offers the following features:
  • File Format Internal Structure : hierarchically organized by file, group, and channel allowing data to be easily organized and interpreted
  • Supported by all NI software development platforms , meaning that any NI software will easily be able to work with this filetype
  • High-speed-streaming-capable: specifically designed for high-throughput applications resulting in the best possible write speeds of any file format
TDMS files can easily be incorporated into your code using the reading from and writing to TDMS files  tutorial.
TDMS files can also be read and modified using Microsoft Excel .
