NI Stepper Configuration Discovery Class A or B Subnet Error
Updated May 3, 2018
  • Integrated Stepper Drive and Motor Device
  • Stepper Motor Drive
Other
NI Stepper Configuration Utility
I am trying to discover my Stepper Motor Drive (SMD) or Integrated Stepper Motor and Drive (ISM) in the NI Stepper Configuration Utility by going to Drive >> Drive Discovery... but I get an window that pops up stating:
Cannot perform discovery on a Class A or B subnet (too many possible hosts).
The reason for the above message is because the subnet mask for your ethernet interface on your computer has a subnet mask that is too broad.  You will need to set the subnet mask to 255.255.255.0 in order to use the Drive Discovery... option.  Refer to Microsoft's Change TCP/IP settings document on how to manually set an IP address and subnet mask on your computer.
With a properly configured subnet mask, you should have something that resembles the image below.
