Is the DSDB Board Supported on Windows 10?
Updated Sep 15, 2023
  • Digital System Development Board
Other
Operating System: Windows 10
I bought the DSDB board and I would like to know if it is supported on Windows 10 and what are its software requirements?
Yes, the DSDB board is compatible with Windows 10. You can find below the software requirements for DSDB Board:
Multisim 14.0.1 or higher, Education Edition
  1. National Instruments Digital Systems Development Board driver
  2. Xilinx Vivado 2014.x or 2015.x
or
LabVIEW 2015
  1. LabVIEW 2015 SP1 FPGA Module
  2. Xilinx Tools Vivado 2014.4
  3. NI Digital Systems Development Board driver
  4. If you use this option, an additional executable must be run. This can be found in  <NIFPGA install dir>/programs/Vivado2014_4/data/xicom/cable_drivers/<nt or nt64>/digilent/install_digilent.exe
Xilinx Vivado 2014.x or 2015.x are not officially compatible with Windows 10. You can compile your VIs through the FPGA cloud service
