LeCroy Wave Series Instrument Driver Files Moved, Missing or Deleted
Updated Mar 23, 2018
  • LeCroy Wave Series Driver
I have installed the LeCroy Wave Series Instrument Driver. I'm trying to verify the installation, by running the example Vi's, but I get the Warning "has been deleted , renamed or moved on disk", on all the example Vi's.
When downloading the LeCroy Wave Series Oscilloscope, Analyzer you will need to first extract the .zip folder.
Once you have extracted the .zip folder containing the required files, you should run the project file to view the examples.
Once you open the project you will be able to access the project explorer window. However if you receive a Load Warning Summary, this will be due the files assosiated with the project not being in the correct/ expected location.
In this example below the LeCroy Wave Series folders path is expected to placed in:
C:\Program Files (x86)\National Instruments\LabVIEW 2017\instr.lib\LeCroy Wave Series
See below:
Following the above example, please place the extracted folder in the 'Expected Dependency Path' , Once you have moved the folder into the correct location, open the project and the Vis/ files will now be accessible in the project.
You will now have access to the files within the project.
Please Note - Each 'Expected Dependency Path' may be different on your own PC.
