Root-Raised Cosine Filtering in LabVIEW
Updated May 3, 2018
  • Modulation Toolkit
I am generating IQ waveforms on my RF device and would like to manually apply a root raised cosine filter to my data. Is there a built-in way to do this in LabVIEW?
If you have NI Modulation Toolkit installed, you can find a VI that performs the square root raised cosine functionality at C:\Program Files (x86)\National Instruments\LabVIEW 20xx\vi.lib\addons\Modulation\Digital\General\subVIs (or C:\Program Files...) called mod_Filter Taps - Square Root Raised Cosine.
This VI can be customized by several input parameters, including Samples per Symbol, Filter Length, and Alpha. The Filter Coefficient output would typically feed into a FIR filter.
