LabVIEW FPGA Xilinx Compilation Tools Not Installed Error
Updated Mar 5, 2020
  • FPGA Xilinx Compilation Tools
Whenever I try and compile my FPGA code I encounter the following error: "Xilinx Compilation Tools are not installed", even though I already installed these tools.
Open the FPGA Compile Worker program and select the configure button. Configure the Compile Worker to use "Connect to a compile server" option instead of "Use the local compile server" option.
Use the following credentials for the compile server:
Hostname: localhost
Username: (blank)
Password: (blank)
