LabVIEW FPGA Xilinx Compilation Tools Not Installed Error
Updated Mar 4, 2025
  • FPGA Xilinx Compilation Tools
Whenever I try to compile my FPGA code, I encounter the following error: "Xilinx Compilation Tools are not installed", even though I already installed these tools.
The FPGA Compile Worker might not be starting automatically due to the Windows security settings. Open the FPGA Compile Worker manually by searching for it and then try to start the FPGA compilation. If it didn't help, select the configure button from the FPGA Compile Worker. Configure the Compile Worker to use the "Connect to a compile server" option instead of the "Use the local compile server" option.
Use the following credentials for the compile server:
Hostname: localhost
Username: (blank)
Password: (blank)
