Unable To Find DAQmx Examples in LabVIEW
Updated Mar 2, 2021
I am looking for examples on how to do specific things with the DAQmx driver in LabVIEW. However, when I go to Help > Find Examples.. I don't see the ones that I'm looking for.
  1. Make sure that you have installed the DAQmx driver  and its examples
  2. The examples you are looking for will be in the Hardware Input and Output > DAQmx
  3.  If you don't see the examples folder for DAQmx. You might have installed a non-compatible DAQmx driver version. Check the compatibility chart and donwload the correct version.
If the example that you are looking for isn't there, it might be a legacy example which you can download separately.
