Can I use Socketed CLIP (Component-Level IP) to connect my VHDL core directly to my R Series input and output?
You cannot use Socketed CLIP on R Series device. The R Series device family only supports User-Defined CLIP interfaces.
CLIP allows you to import and use previously developed VHDL in your LabVIEW FPGA VIs. Socketed CLIP allows you to interface directly with FPGA I/O and FPGA VI.
A valid service agreement may be required, and support options vary by country.
