The IMAQdx Runtime does not include the functionality that allows you to configure your camera in NI MAX or open a session to a camera using an alias name. To get this functionality, you can either:
- In your LabVIEW Project, right-click on Build Specifications and select New»Installer.
 - In the Installer Properties window, select Additional Installers.
 - Uncheck the boxes Automatically select recommended installers and Only display runtime installers.
 - In addition to the NI-IMAQdx Runtime, check the box next to NI-IMAQdx Development Support.
- Build the installer and run it on your target computer to include the ability to configure your camera in NI MAX.
In older versions of the NI-IMAQdx in the additional installers options you'll find NI-IMAQdx instead of NI-IMAQdx Development Support, in those cases that package would include all of the driver functionality including the needed NI MAX support. However, NI-IMAQdx Development Support does not exist as an option for 19.0 and onward. Please reference the article NI-IMAQdx Development Support Missing from Installer Builder in 2019 for more information.
