Archived:Accessing Shared Variable from LabVIEW NXG 2.0 Web Module
Updated May 3, 2021
  • LabVIEW NXG Web Module
  • LabVIEW NXG 2.0 Full
Can I access shared variables from NI Shared Variable Engine in a Web Module VI?
Reading data from the Shared Variable Engine is not supported in LabVIEW NXG 2.0 Web Module. To transfer data to a Web VI you will need to use the SystemLink API or the HTTP API.
