I have a LabVIEW application that uses shared variables. When I try to deploy the executable, I receive the following error:
Variables deployment failed (error: -2147220721, MAX: (Hex 0x8004030F) The configuration database cannot be opened, possibly due to corruption. Please note the steps you performed that led to this error and contact technical support at http://ni.com/support).
When I run my application, I get the following error:
MAX: (Hex 0x8004030F) The configuration database cannot be opened, possibly due to corruption. Please note the steps you performed that led to this error and contact technical support at http://ni.com/support.
