Wiring Multiple Floating Differential Inputs On the NI 9205
Updated May 10, 2024
  • NI-9205
I see on page 18 of the NI 9205 getting started guide it mentions a 1MΩ resistor when connecting a floating differential input. Do I need to wire this resistor for each differential input, or can I use a single resistor for all the analog inputs?
All of the negative input channels are connected to the same common node, so you can use a single resistor to connect all the negative signals to the COM input.
This is the case because the resistor is intended to keep the overall single ended voltage input within the card limits. This high resistance element is intended to do this for all differential pairs connected.
