Can I Use Softmotion Lite with Multiple Motion Axes?
Updated Mar 22, 2018
  • Stepper Motor Drive
  • LabVIEW SoftMotion Module
I have multiple Stepper Motor Drives (SMD) that I want to control over Ethernet from my cRIO. Can I use SoftMotion Lite to control multiple motors?
The answer to this question depends on what you are trying to do with multiple motors.
If you are needing to have multi-axis control (synchronized moves, gearing, camming, etc.), you will need the full version of SoftMotion.
If you do not require synchronization, you can address motors individually and use single-axis point-to-point moves using SoftMotion Lite.
For more information on whether SoftMotion Lite is applicable for your set up, consult the SoftMotion Selection Guide.
