How to Know The Range of My Data Acquisition Device Programmatically in LabWindows™/CVI™
Updated May 3, 2018
  • LabWindows/CVI
I have several data acquisition devices, such as PXIe 6343 and PXIe 4300.
I would like to know the analog input ranges programmatically before creating a task.
In order to obtain the possible ranges from your data acquisition device, in LabWindows™/CVI™ you would call DAQmxGetDeviceAttribute() and in the parameters for the function you would choose which attribute you wanted to get.
In this case, you need to select the parameter DAQmx_Dev_AI_VoltageRngs
Here is a code example of how to know the range of two devices:
TaskHandle  taskHandle=0;
static float64 Range[10];
static char DeviceName[100];
static char Device1[10];
static char Device2[10];
        DAQmxGetSystemInfoAttribute (DAQmx_Sys_DevNames, DeviceName, 100);
        Scan (DeviceName, "%s>%s[xt44]%s[xt44]", Device1, Device2);
        DAQmxGetDeviceAttribute (Device1, DAQmx_Dev_AI_VoltageRngs, Range, 10);
According with the NI DAQmx Help:DAQmx_Dev_AI_VoltageRngs
Data Type :    float64 *
Description :    Indicates pairs of input voltage ranges supported by this device. Each pair consists of the low value, followed by the high value.
Example: If I have a device that has two ranges: +-1V , +-10V, the output will be [-1.0, 1.0, -10, 10].
