Max Input Current For NI TSM-1012
Updated Mar 22, 2018
  • TSM-1012
What is the maximum input current for the NI TSM-1012?
The NI TSM-1012 needs 9-16V and 6.67-1.67A. There is also a sticker stating this information attached to the device. The TSM-1012 simply needs ~60W of power, so the maximum current it will draw depends on the supplied voltage. Depending on the voltage you will supply, this information should be able to calculate this for you.
