PXIe Chassis Backplane Pinouts
Updated Apr 10, 2025
  • PXI Chassis
  • PXI Platform Services
I'm developing a custom PXIe board which is compatible with NI-PXIe chassis.
Where can I find reference documents for PXIe chassis backplane pinouts?
First, if your device under development is a PXI type, not a PXI Express(PXIe), check this KB about PXI pinout.
You can find the pinouts at the end of the PXIe chassis user manual based on your model.
However, you may need more references to understand how to apply this to your model.
PXIe is a standard that leverages the electrical features defined by the widely adopted PCI Express specification for data movement.
Refer to the PXI Express Hardware Specifications at pxisa.org  for more information.
For example, if you use PXIe-1071 chassis, you can find the pinouts at NI PXIe-1071 User Manual page 47(Appendix B).
